10-15mm gap under insulated plasterboard?
AzK
25 Dec 2020
Hi
I have bought a couple of insulated plasterboards (Knauf XPS Laminate Plus Insulated Plasterboard Tapered Edge) to go on a ground floor external wall that is cold and it cant be insulated externally.
I understand that on ground floors, you need to leave a 10-15mm gap between the bottom of plasterboard and the floor to avoid any damp or moisture rising up through the board.
My question is as I am trying to insulate a cold wall, do I just leave this gap of approx 10mm x 27mm hollow? I am worried about both heat escaping and also coldness coming through this gap.
I have seen in some places that people suggest using skirting board - whilst this visually covers the gap it doesnt quite deal with the issue of insulating that area.
Any reccomendations or suggestions? Is there a foam or other product I can use to fill to both fill the gap and that is moisture resistant?
What is the floor made of? Timber or Concrete?
The fitting of a Skirting seems most appropriate
Ken
Ken
Hi. It's a concrete floor with laminate (plus the usual underlay etc)
If you need to fill the gap you can get closed cell foam piping (e.g. Fossa CaulkSaver) from decorators wholesalers and some places on line in a variety of sizes
If the floor isn't insulated then the heat loss through that junction won't be the first thing to tackle.
For the gap you can use a flexible insulation or a foam as suggested.
Also note that Knauf XPS Laminate Plus does not have a dedicated water vapour resistance barrier.
