- Joined
- 27 Jan 2008
- Messages
- 29,489
- Reaction score
- 3,627
- Location
- Country
Went to doctors on it mainly to test it before my wife uses it, just fitted two new 35 Ah batteries, and it failed on the return leg, and had to push it home.
The volt meter went to zero, and the brake engaged with a bang, which it would with power failure, tried the 40 amp circuit breaker and no luck, since nothing seems to have power, would suspect either that or one of the two 125 amp fuses.
There is also a 3 amp fuse and a 8 amp fuse I think the latter only to do with charging, I was whacked on return 67 kg and can't fully disengage the drive, so hard pushing, so going to start in the morning.
First will be the battery pack, but any pointers as to possible failure, it is some 16 years old now, although not used that much, still on original tyres, it has been parked up for some 3 to 4 years with faulty battery, new fitted around June, but this is first real trip with new batteries.
