Hi all,
So I have some spare GA4100 celotex after using it for between the roof rafters.
I should have enough remaining to provide a 100mm installation floor base and 75mm screed. Is GA4100 safe to use with ufh? Will the compression be too weak or will the foil cause issues? Ideally I would avoid buying more, but don't want problems later on.
Thanks in advance.
Thanks in advance.
