- Joined
- 15 Apr 2018
- Messages
- 256
- Reaction score
- 1
- Country
Hi all,
Boiler is a Glow worm Ultracom 30cxi
Our shower is starting to run hot and cold , We had this before ( about 4 years ago) and it was the DHW heat exchanger, this was replaced and all was good.
So the plumber has said he can replace the heat exchanger for £250.
As I can buy a replacement HE for £50 it seems a lot for the labour ( reading about it , it seems to be about an hours work)
From what I can see its a matter of isolating the boiler water supply and mains, draining the boiler and then swapping the unit out.
Is this correct? and if it is what is the best way to drain the boiler ?(There seems to be a view of not to use the PRV for draining.
Many thanks in advance
