I know this problem has been asked before and I have looked at alot of replies but can I pick someones better knowledge than mine. I have open vent system which has been running fine for some years now. It had a power flush about 7 yrs ago and have not had to bleed a radiator since, before that I was bleeding 2 or 3 upstairs rads every week. There are 10 rads or 11 if you count a double in the main lounge in a 3 bed house. The system had an inhibitor top up last year. Yesterday the rad in the kitchen and one the other side of the wall went cold. I turned off all the other rads, no trvs on them, and the heat returned, great I thought, later though the one in the downstairs toilet went cool, repeated procedure as before, rad got hot, opened all valves again later on just before retiring it had gone cool again. Heating off overnight, after system had heated up this morning the problem rad got some heat but not as hot as all the others. Later it went cool again, did the valve closing on all the others and the rad got hot again, I could hear a tinckly rattly sound, ?air, for a few minutes but stopped after 5 mins. Turned all rads back on but it has now gone cool again.
Why has it suddenly decided to do this, if airlock why does rad get hot then go cool again when system fully open? Have tried bleed valve but no air in, when hot it is hot all over. Any advice would be welcome.
