T
teaboyjim
Is it ever acceptable lay electrical cables in the screed?
If the electrician did it in screed then he would do the work and sign it off.Who's signing off the documentation "someone" or the electrician.
I think they thought it was a hazard to someone breaking or cutting the floor in the future.You need to find out why he frowns on such behaviour.
Regulation 522.6.4: “A wiring system buried in a floor shall be sufficiently protected to prevent damage caused by the intended use of the floor.”
It is very common to install cables in round high impact conduit in screeds. The conduit is usually fixed to the floor screed with galvanised saddles without the spacer bar. Ideally the conduit would have hand pulled bends at the walls and be terminated at accessories with a female adaptor. Some firms spec galvanised conduit for floors, but the regs do not specifically require it, the regulation above is quite woolly. The regulation following the one above references suspended joisted floors, and does require a depth of 50mm or earthed steel conduit, but it doesn’t reference solid floors at all, just joisted.
That argument could be applied to any cable buried in any structure, be it a wall or a floor.In general I think it was considered bad practice because it could be a hazard to someone breaking or cutting the floor in the future. On the face of it it does make sense
