Texecom Area Setup HELP
14 May 2009
Dundee
Hi All,
After some help please, I have a Tex 88 with Wintex for config, Smart Com etc. All working great, I have added a new Keypad, Door Sensor and PIR in my garage and set them all to Area B, everything else is set in Area A.
Hope that is correct, so far. What I am trying to do is set it so Garage is armed separate to the house. How do I set this? e.g. leave garage armed all day, while house is no armed, and able to disarm when entering.
Set keypads areas , set local arming / disarming for code , set your code to areas A B ....so if you come in to the house it will only unset the house and same for the garage ...
So all working, but I don't seem to get any email notification from this area when armed or alarmed via Smart Com, the main house alerts are all working fine, so did I miss something?
Cheers
Hi, I have literally just opened a new thread asking the same thing (with some other setup questions). Please can you explain where in Wintex to find the 'local arming / disarming for code'? Apologies, I am sure it is obvious for most!!
In comms menu / arc 1 / will be texecom connect ...scroll down what areas are in this ?
