Lower ceiling 1 (duplicates merged)
23 Jan 2006
Manchester
I want to lower my first floor ceiling to get extra height in the loft but how would I suitably tie the new floor to the roof structure to prevent the roof spreading.
It’s not just a matter of lowering a ceiling though I doubt you have enough ceiling height to lower unless your in a house with 10ft + ceilings.
Get a structural engineer to design you a solution.
It is feasible, but messy.
In principle, you tie the existing rafters back to the new (lowered) floor joists with suitably-angled pieces of timber, such as 200mm wide strips of 18mm ply.
You may also need to form bulkheads around the tops of the first floor windows if your new floor is to be below the tops.
It depends on the type of roof structure. You have given far too little information for anyone to even make a guess. A few photos from inside the loft space might help here
The joists prevent the rafters collapsing like a house of cards (rafters moving outwards)
This needs structural calculation and a lot of detail of construction of your roof as is.
Yes it can be done - but likely to be a lot of work .... consider other options ..... office as an outbuilding in the garden ?
I have done this job once on a terraced house with a purlin roof. Because the roof purlins already carry much of the weight of the roof spreading isn't an issue, but getting structural steels in to carry the joists was heavy work and cutting down walls, etc was a very, very messy job. Never again!
I don't think sully has a good track record of responding ....
It's all hearsay anyway unless they have the ceiling room to lose beneath the loft.
Here we are
If you cut out those joists, your house will fall down. The roof will push the walls apart.
like this
https://metro.co.uk/2016/06/08/dram...se-660000-collapse-during-renovation-5932499/
Observe the work done by the "builders" prior to the collapse:
350F01C900000578-3631346-The_house_was_sold_in_January_and_has_been_under_development_sin-a-56_1465398584116.jpg
