OH my oh my.... that boring old chestnut yet again.It is not nonsense. It is frequent and people should care if the errors are dangerous like this one you will have seen before.
OH my oh my.... How stupidly predictable can an idiot be? That boring old chestnut yet again.It is not nonsense. It is frequent and people should care if the errors are dangerous like this one you will have seen before.
Except this case appears to prove that MI's instruction may be, in fact possibly definitely, correct as the fire could not have possibly occured if the isolator had been operated after the last use.I have done. Saying that the shower isolator should be used after every shower is wrong.
I'm not personally necessarily suggesting that one doesn't - but, as I've said, adding an isolation switch introduces an extra thing to go wrong (we see quite a lot of posts about problems with shower isolators) and, perhaps more importantly, is the fact that at least 'burned wires' (hence perhaps a risk of fires) seems much more common in shower isolators than in showers themselves. ... so it's not a totally one-sided decision, with only 'laziness' on one side of the argument.
In practical terms, one issue which has not been mentioned is that, even for the lazy, it is not too much effort to install a ceiling-mounted isolator (with a pull cord) on the ceiling IF the supply to the shower comes from above. However, if the supply comes from below, it is much more of a mission (which might put off even the non-lazy) to fit an isolator, not the least because of the restrictions as to where any sort of switch is allowed to be located in a room containing a shower.
Have you omitted a "not"?So once and for all please stop this stupid assertation that the isolator should be switched off when the shower is not in use.
The extent to which it is a 'no-brainer' probably depends upon how often it is going to be used. If (as seems to be the norm, rather than the exception) it is 'never' going to be switched off, then maybe one would have to ask whether it is a 'brainer' or 'no-brainer' to install something which was never, or virtually never, going to be used.I have to say, I'm in agreement with RF here. An isolator is a no-brainer. An easy to reach DP means of isolation that will result in minimum inconvenience to other users of the installation if deployed.
Nor have I, but most of the switches I know about are ones that I have installed myself ('properly')Also, WRT failed switches, I have not knowingly had a DP switch failure due to a poor connection in any of my installations.
Fair enough.I must admit that we switch off after every shower (Mira Sport). The manufacturer's booklet says to do this so what would my insurer say if there was a fire? I like the idea that there is no electricity coming into the bathroom apart from the lights.
We could. Certainly (unlike the situation with 'fan isolators') none of these discussions have had anything to do with 'isolation' - they are all about the desirability of having a local 'emergency switch' available.We could stop calling them isolators.
They do, but I wouldn't be too surprised if a clever lawyer (or even Trading Standards) managed to turn that "ar$e covering" on it's head. If the manufacturer is implying that something catastrophic (like catching on fire) might happen to their product when not in use if it were not isolated from the electricity supply, then one might question its "fitness for purpose" and/or compliance with relevant Standards/regulations/legislation.Manufacturers often print ar$e covering instructions, as an aid to passing blame onto the customer for faults and failures.
Yet again sorryHave you omitted a "not"?
Are you trying to infer nothing can fail?They do, but I wouldn't be too surprised if a clever lawyer (or even Trading Standards) managed to turn that "ar$e covering" on it's head. If the manufacturer is implying that something catastrophic (like catching on fire) might happen to their product when not in use if it were not isolated from the electricity supply, then one might question its "fitness for purpose" and/or compliance with relevant Standards/regulations/legislation.
That raises another tangent as so often happens.Imagine if you (or Trading Standards, or a Court) were to read on MIs something like "since this mobile phone may spontaneously burst into flames when not in use, it must be stored in a fire-resistant enclosure when not being used"
