Hi, I am planning to fit an electric shower and would like to install a timed extractor fan at the same time. I would like the fan to operate during and after the shower is switched on, and NOT every time the light is switched on.
I have run a dedicated circuit from the consumer unit (RCD protected) to the electric shower via a ceiling mounted isolator switch. I would like to know if it acceptable to wire the extractor fan from the shower isolator switch? And would I need a fuse between the isolator switch and the extractor fan? This is the only way I can think that will allow the timed extractor fan to operate during and after the shower is switched on, and not every time the light is switched on.
My major concern is safety so if this is in anyway dangerous please let me know and I will install a separate isolator switch for the extractor fan running from the ceiling rose.
