- Joined
- 21 Feb 2021
- Messages
- 396
- Reaction score
- 2
- Country
They look like fluted wood dowels. Pull it open a bit more if you can, gently - don't force it, add some PVA wood glue around the dowels using a cocktail stick or match stick (don"t be stingy) then push the joint shut slowly. I'd recommend placing the drawer on its' front (face down) with maybe a couple of storage boxes or old books beneath the face of the drawer to give a bit of clearance for the handle(s), and a heavy weight (maybe 4 or5 kgs) on the back edge of the drawer to keep the joint(s) closed whilst the glue sets. Leave at least 12 hours to set fully, but wipe off any glue squeeze out immediately.
They look like fluted wood dowels. Pull it open a bit more if you can, gently - don't force it, add some PVA wood glue around the dowels using a cocktail stick or match stick (don"t be stingy) then push the joint shut slowly. I'd recommend placing the drawer on its' front (face down) with maybe a couple of storage boxes or old books beneath the face of the drawer to give a bit of clearance for the handle(s), and a heavy weight (maybe 4 or 5 kgs, no more) on the back edge of the drawer to keep the joint(s) closed whilst the glue sets. Leave at least 12 hours to set fully, but wipe off any glue squeeze out immediately.
Simple small L bracket at top front on either side with strengthen to prevent reoccurrence.
No screw L bracket to drawer side and rear of drawer front at top .L bracket? How do you mean? I'd have to nail an L bracket into the wood somewhere? Where would you nail the L bracket? The door has to open it has to be free and loose to pull open but maybe I've misunderstood you.
After that I left it to set, I couldn't put it face down on it's front as the two knobs don't let me.
As did I
The angle brackets are screwed to the front inside corners of the drawer, one "wing" is screwed to the back of the drawer front and connects it to the drawer side, thus:
