Hi all,
After a bit of advice, considering 2 options for building a snooker room at the end of my garden. It will be a full sized table so need minimum internal room size of 22' x 16' so was thinking of going with a 8m x 6m area for the base.
I am thinking either single skin block, rendered and then baton inside with insulated walls, floor and ceiling and all plastered with a sloping flat roof.
Other option is a log cabin like this one: https://summerhouse24.co.uk/large-g...IPOFVaXBBsMhT4xW-19kpbNRPq8as38QaAuDpEALw_wcB
I can't decide what would be cheaper, easiest and best for value. The wooden summerhouse option with foundations and all the insulation extras etc comes in at I'm guessing around 18-20k.
I'm a fairly competent person when it comes to DIY, and happy to do alot of work myself, but get tradesmen in for certain aspects, and call in trade friends where I can.
I'm know the foundations will need to be pretty solid due to the weight of the building and the snooker table itself, and as I want to be able to use this room all year round I'm guessing an insulated concrete screed floor would be best.
I personally think the brick built building will also add more value to the house due to its more permanent structure, we are also having our current double glazing replaced so I could re-use some of the old windows and patio doors to save money on this build. And I am aware that planning will be needed due to the size of the structure and the proximity to the boundary as I want it as close to boundary as possible. It will however take up less than a 1/4 of the garden.
Any advice and suggestions would be greatly appreciated. Thanks in advance.
Also, if any builders here are in the Colchester, Essex area and fancy coming and quoting for some of this work then feel free to let me know.
Cheers
Cheers
