- Joined
- 27 Jan 2008
- Messages
- 29,070
- Reaction score
- 3,561
- Location
- Country
After the bulk charge stage my battery chargers are designed to maintain the battery, it is rather simple there is zero, 0.1 amp and 0.8 amp charge rates, and two voltages 12.8 and 14.4 if the voltage drops below 12.8 it ups charge rate, and above 14.4 it drops charge rate, this is claimed to be better than floating at 13.4 volt as it equalises cells better.
I have three cars and another 6 batteries from caravan and jump-start set and some 7 Ah from old stair lift which will be used for my radio. Plus two which use a dedicated charger for mobility scooter, and all but one charge A1 the charge rate will in the end drop to zero with likely once a day charger switching back on to top up charge, even the 95 Ah AGM on the Jag drops to zero charge rate after some time, switching back on at 11:40 am every day, clearly some thing in Jag auto switches on at that time.
Batteries which are older never switch off, they sit at 0.1 amp charge rate, but 95% of the time sit at 12.8 - 12.9 volt and get a pulse every so often to maintain them.
The odd one out is on a Kia Sorento, flooded 95 Ah battery, to start with all seems normal, it goes through each stage until it drops to 0.1 charge rate, then like the other batteries maybe 10 hours latter it gets a ½ hour pulse at 0.8 amp, then drops back to 0.1 amp again.
But as time goes on both the time between the pulse gets shorter and pulse length gets shorter, so I end up with some thing like this
with loads of pulses per hour, only the Kia battery does this, no other, all other batteries will be left on charge for around 2 weeks then charger moved to next battery, and with a 0.1 or 0.8 amp charge rate I don't really worry about exactly when moved to next battery, if I had more chargers or less batteries I would not take them off charge, just this one battery that does this.
So does the pulsing do any harm? I have read conflicting reports on pulse charging, and I don't think this is what is meant by pulse charging, some very cleaver chargers use the decay between pulses to work out charge state and so charge rate, common with canal boat batteries but looking at chargers able to deliver 120 amp and charging 400 Ah battery bank, so not really the same as my 3.8 amp charger with a 95 Ah battery.
So what is going on, is it slowly removing a build up of hard sulphur, so I should leave it longer, or is the rapid pulsing damaging the battery?
My intention had been to fit the old Jaguar XE battery into the Kia Sorento and put the Kia Sorento battery in the caravan, as think the old Jag AGM battery is better, and also may be damaged with the caravan power supply which seems a tad high on voltage, the flooded battery I can top up with distilled water. But not sure if I need a code for Kia on changing battery or if any reprogramming required? So was waiting until licence sorted and can take it to Kia agents.
It is the problem of moving from paper to photo licence now 70 which has resulted in the cars not being used and sitting in the drives, seems on line renewal is done by letter! And I need some one who has known me for 3 years to sign photo, so waiting until I have been in this house for 3 years before I can get some one local to sign licence paper application called the on line renewal form before I can get licence renewed. And clearly since not using bus or train has to be within walking distance.
with loads of pulses per hour, only the Kia battery does this, no other, all other batteries will be left on charge for around 2 weeks then charger moved to next battery, and with a 0.1 or 0.8 amp charge rate I don't really worry about exactly when moved to next battery, if I had more chargers or less batteries I would not take them off charge, just this one battery that does this.So does the pulsing do any harm? I have read conflicting reports on pulse charging, and I don't think this is what is meant by pulse charging, some very cleaver chargers use the decay between pulses to work out charge state and so charge rate, common with canal boat batteries but looking at chargers able to deliver 120 amp and charging 400 Ah battery bank, so not really the same as my 3.8 amp charger with a 95 Ah battery.
