Ok.
Where would this borrowed neutral be in what I wrote?
Nor to mine.That would not apply to what I suggested.
Ok.
I don't really understand what you are getting at.You wrote- 'Or, of course if easier, you could just have a new light and second switch downstairs which is the usual set up.
Cable from light to switch and either from CU to switch or light.'
Which a complete amateur could assume from that any neutral would do - if you do not make it clear.
Obviously if he chooses to fit a new light and switch, all conductors must be connected to the correct place.
How can you borrow a neutral when installing a new circuit?
No, that's not what I said.Quite easily. I would expect the OP to want to swap the 2-way switch for a 2-gang and thus pick up a live from the existing 2-way circuit which will likely be on the upstairs circuit.
My interpretation of your post; run a T&E from CU to either light or switch and run a T&E between light and switch.No, that's not what I said.
