- Joined
- 27 Jan 2008
- Messages
- 23,679
- Reaction score
- 2,668
- Location
- Country
Sorry 100 times a second or 50 Hz. Had a senior moment.You should definitely send back the ones that flash at 100 times a minute.
All of the decent mainstream manufacturers of household incandescent lamps are gone.
Tungsten Halogen lamps occasionally used to explode
When I had fuses I had no problem, even with ionisation (bright flash) when the filament ruptured it would not rupture the fuse, however when I swapped to MCB's then it was common for ionisation to trip the MCB. I have seen people call a MCB a fuse.
I found on swapping to CFL then LED I also needed to replace the thermostat with a programmable type. As in the evening need the temperature raising a tad, the tungsten bulbs did this with the inferred output, but the new low energy lamps do not assist with heating. I also found 11 watt CFL or 7 watt LED does not equal 60 watt tungsten so my 3 bulb chandelier was swapped to 5 bulb, and in this house 8 bulb instead of one 100 watt.
But LED's flashing when switched off and shimmering when running has been a problem, swapping bulbs did cure it, oddly using cheaper ones, but to say change to LED is easy, but to actually change, if all BA22d bulbs OK, but with GU10, and G9 I have found problems.
I presume you mean infrared output rather than a deduced output......the tungsten bulbs did this with the inferred output,.....
Shimmer when on, flash when off, we have wifi switches in bedroom so can use a remote by bed to turn lights on/off, easier than rewiring with two way lighting, these bulbs were a problem, both would not switch off and shimmer when on, the switching off cured with one of these which leaks away the slight current through switch which causes the flash then wife got these, far bigger and the covers will not fit over the bulb which is about same size as a E14 bulb, even when G9, within a day one failed, got replacement and decided to open the failed but to see what was inside it, and found a dry joint, so fixed and went back into service.I'm all LED, but none of mine shimmer when off.
Have the roads got lampy names like Bayonet Drive, Filament Avenue and Ballotini Way?The Crompton lamp factory used to be just up the road from me but sadly closed down 20 years ago and is now a housing estate.
Indeed - and, as I wrote to him recently (post#6 above), if he doesn't like Amazon, then he has to look no further than Wickes or B&Q etc.Eric.... Fuse wire cards are up for sale in Amazon for a couple of quid.
