How to cut a cone into wood?
22 Sep 2017
Hi guys.
Does anybody know how i go about cutting/routing a cone shape into a piece of wood? I need to replicate the picture attached.
As Tiger says. a cone cutter.
Make sure you can get one to cut to the widest diameter you need. Drill a pilot hole first, insert the cone cutter and away you go.
You could use a piece of tape around the cutter at the finished diameter you want. Saves taking the cutter away and measuring numerous times.
No way!
OK, next question ... what's the purpose of a cone-shaped plug - "to fit a cone-shaped hole" is not permitted as an answer.
