yes you can do it that way, just be aware that not all valves have the same thread and some you need to cut the olives off if replacing with a different brandIt's on an open vented system. Would there but much hope of swapping this by bunging the open vent an feed pipe to create an airlock. Have never tried it before.
Yep as already said it is an old EPH just get the same actuator, no need to drain anything , and no need for any rewiringThis is the valve any ideas if they still make this model.
You will need a 3 port valve head, as opposed to a 2 port.How do I know if the new EPH one will have the same actuator? Would I need to email the manufactures?
It is the same valveActuators almost always have to match the water valve - if you swap actuator, then you will almost certainly have to drain the system down and swap out the valve too.
