Extending Aerial Cable
30 Jun 2005
Hello
I wish to extend an aerial cable in my bedroom as I’m moving the TV to a different position. I will be lifting the floor boards and extending it under them. What’s the best way to do this as once the floor goes back down I won’t have any access to the join if something goes wrong. I’ve attached a pic of the end of the cable which seems very thin.
Thanks for your help.
the good news is that your existing cable has an f connector on the end of the cable. it also has an adpter that goes from f connector to coax. so to join another length of cable to it you will need a joiner like this
https://www.ebay.co.uk/itm/124609358925?hash=item1d034bec4d:g:6OAAAOSw2XJgP8T7 and two f connectors like this
https://www.ebay.co.uk/itm/254471156317?hash=item3b3fa9b25d:g:tfQAAOSw96leD8BS
unscrew the adapter ( the bit on the right) from the f connector and screw in the joiner, on one end of the new cable fit one of the new f connectors then screw that to the joiner, tighten up the nut like bits with a small spanner (11mm) till it is not loose or liable to come loose. you can also cover the join with heatshrink sleeving if you wish to isolate the metal and to ensure that the nuts dont come loose. then fit the other new f connector on the other end of the new cable and fit the old coax adapter to the f connector and plug the new cable in to the tv to test before you put the floorboards back down!
how to fit f connector https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiN7sGD7_vwAhWV7eAKHQveCAgQwqsBMA16BAgIEAE&url=https://www.youtube.com/watch?v=okYPFai6I4I&usg=AOvVaw1FlvhVTR5YKap8Gi2yqjhr
if it is easier you can buy ready made leads but some of the ones leave a bit to be desired in the cable dept. this one seems to be ok though
https://www.ebay.co.uk/itm/264903330399?hash=item3dad780a5f:g:7GIAAOSwULZgCJLc
how to fit f connector https://www.google.co.uk/url?sa=t&r...=okYPFai6I4I&usg=AOvVaw1FlvhVTR5YKap8Gi2yqjhr
Thanks Suritsoff. What size co ax cable do you recommend for the extension?
If you know the length of cable you need, I can supply you a full kit using Webro WF100 coax (white or black) - all copper; the best coax you can get without going stupid daft OTT - fitted with a compression connector including O-ring moisture gasket, an F-type back-to-back joiner and double layers of heat shrink tubing for extra peace of mind.
At the TV end you can have your choice of straight or 90 degree right-angle coax TV plug, whichever suits your plan the best.
I think I need about 5 meters thanks
Unless you know for sure that 5m is plenty to go under the floor and then up/down a wall and still leave enough to reach the coax socket then I'd go with the suggestion from @Sureitsoff? Spec it a bit longer.
We can sort out the rest of the details such as jacket colour, type of aerial plug (straight or 90 degree, address details etc via the 'Conversations' feature which is how we private message here.
You'll have to enable that first in your user profile. If you're not sure then here's how:-
click on your own user name
Select Privacy from the menu, then look to the bottom of that newly-opened menu. There'll be the option to enable conversations. I have mine set to members only. Save your changes.
(you can always disable it again after we've sorted detail's and all is done.)
Now come back to this thread. Click on my user name, and then from the little menu that opens choose the Start new conversation option.
Conversations are private messages bewmtween forum members. The details don't appear on the forum, so things such as addresses and phone numbers remain confidential.
(y)
