how to measure existing shower cable?
20 Jul 2019
Hello
the current Mira 7.5kw shower is packing up, plastics has cracks and replacement parts are hard to find and so we thought we should upgrade to a 8.5kw shower. it has 40A mcb on the fuse box.
how do i measure the existing shower cable, the prints on the cable are badly scratched so i cant read what it says. do you measure the outer grey sleeve or individual wires?
thanks guys
Measure the copper core diameter with a micrometer and calculate the cross sectional area using pi times dia squared divided by 4. Multiply by the number of strands.
Measure the copper core diameter with a micrometer and calculate the cross sectional area using pi times dia divided by 4. Multiply by the number of strands.
hahahahaha!
I used to find it hard to identify 4mm cable by eye as I seldom saw it.
if you buy the smallest possible pack of cable clips in common sizes (1mm, 1.5mm, 2.5mm, 4mm, 6mm, 10mm) you can mark them with a stabilo pen and keep a set in your toolbox. Practice clipping them on and off and you will soon recignise the difference between "too tight" "perfect fit" and "too loose."
13.19mm x 7.02mm
does that mean it has 6mm cable?
Why don’t you measure the copper core with your gauge and calculate it as I have already explained? Much better than guessing using the sheath measurements.
Edit. Just noticed picture
Not a fan of using Metal calipers on Electric cable.
damn, i dumb at math.
each core has 7 copper strands and each copper strand is 1mm
no idea how to calculate the cross sectional area. i think i'll leave it and get an electrician to find out for me.
You wrote " diameter" and also "dia" are these different things or just another bit of lazy writing by you when imparting low value advice.,
Suppose the OP does not have a micrometer, would you advise him to buy or hire one
I don't know where this table originated but generally it seems to work
why not, if the power is off from the fuse box. i've already checked with a multimeter.
I think its potentially dangerous.
I would want to be 100% sure I had safe isolation before using a metal caliper on an electrical cable.
A multi meter is not an 'Approved' voltage indicator
It is difficult to know if a multi meter is working, or it could be on the wrong setting.
Get an off cut of 6 and 10mm 2 cable and compare. The difference in size is quite apparent, side by side
That - 1.04 - is the same as in the wiki link I posted, although both should actually be 1.09mm.
Edit - I am wrong. The figures are correct. Sorry
after turned off from the fuse box, the shower no longer starts. my mutimeter its a fluke 115 and i use it everyday on laptops repairs. i use ac mode on the mutimeter for checking home electrical.
yep, i think mine its 6mm. it has 7 copper strands and 1mm each copper strand. 13.19mm x 7.02mm grey sleeve.
so 8.5kw could be fine. but just to be safe i gonna find another 7.5kw shower to replace with as i dont want electrician to replace the cable to higher rating as it will cost a lot of money..
