Hello and good morning, hope someone can or knows what this pump on my system do and how, please look the enclosed photos
The plumbing on my house has been done around 2002 , it has 2 conventional Alpha boiler next to each other ,I have no problems at all for now with the system.
What puzle me is the pump on the right hand side of the Megaflow.
That pump is connected on the same timer of the boilers and have discovered that when pump is running i get instant hot water on all taps of the house. If I switch of the concerned pump , then it takes 10 to 15 seconds before hotwater reach taps.
The pump is connected to the flow at the bottom of the Megaflow and the other side of the pump to a T , from there to 2 small white pipes going under the floor board, no idea from there where they going.
Hope some one can explain this to me .
Thank you
Thank you
