DON’T TELL PEOPLE TO IGNORE ME OR ANYONE ELSE.Ignore Winstons comments he can never make up his mind what he wants to say, on a previous thread he went overboard explaining why the splitter SHOULD BE installed.
What would you recommend?
It would give me more options
One day, I may want to add a TV to the room above or use the existing antenna point?
Is 4db loss significant?
In an ideal world I'd agree to keep the cable separated but have a look behind the average TV setup of yesteryear with VCR, SKY, DVD, 5.1 amp etc and very possibly record dec, cassette machine, CD player, MD recorder etc and see the massive tangle of all sorts of cables not interfering with each other.Running an aerial and mains lead together may cause interference from the mains to be induced into the aerial. Best to keep the two feeds apart in separate trunking.
A 4dB loss should be tolerable with a good aerial system. I asked why you wanted it and you have explained. Don’t put an amplifier in it you don’t need it. All amplifiers add noise.
Not wanting to destroy another thread I'll reply elsewhere.DON’T TELL PEOPLE TO IGNORE ME OR ANYONE ELSE.
You cannot remove noise once it is added.
Please go back to electrics that you understand and leave RF to those that know
Likely, the antenna cable will either come down inside the wall from above, or up the wall from below. If you can lift floor boards to gin access to the coax cable, you could then run it straight down from the ceiling (or floor). You could then chop it into the wall vertically, or in a vertical run of mini trunking. A single vertical run of trunking looks much better than an horizontal + vertical run I find.
Maybe, but he would still need an aerial for these recorders.Quite apart from the other "discussions" generated from this posting, I am quite surprised that there are persons who still choose to install a "set-up" whereby they just watch TV programmes
Mat the times at which broadcasters of those programmes choose to transmit them.
Also, broadcasters tend to put the "good" programmes on at the same time of day, resulting in the viewer having to choose and (possibly) miss programmes which he/she might wish to watch.
While "catch-up" TV is available, via Chrome-cast (or other devices), recorders which can record programmes from several Digital TV channels at the same time and then play them back at a time more suitable to the viewer are available - at about the same price (or less) than that of the wall mounted TV depicted in the first post.
One wonders if veedee has considered these options.
Quite apart from the other "discussions" generated from this posting, I am quite surprised that there are persons who still choose to install a "set-up" whereby they just watch TV programs at the times at which broadcasters of those programs choose to transmit them.
Also, broadcasters tend to put the "good" programs on at the same time of day, resulting in the viewer having to choose and (possibly) miss programs which he/she might wish to watch.
