- Joined
- 2 Jul 2021
- Messages
- 23
- Reaction score
- 1
- Country
Hello all,
I have been following the forum and tried searching various threads on Hive installation with Potterton Promax HE Store (Baxi) combi boiler but seems like I was getting even more confused due to some wiring arrangements. Decided to get a plumber to fit mine for me and low and behold - the Hive thermostat does not switch on my central heating. The hot water still works fine. I have tried various adjustments of the programmer on the boiler although I am told I need to leave this as ALWAYS on so that the Hive can control CH independently. The plumber has been over again and says he has checked all the wiring but cannot understand why the Hive is not working – he tells me the boiler is now at fault although before the changeover, the boiler worked fine with old wired thermostat (Honeywell CMT707A).
However, if I switch HW off and then cycle the boiler setting for CH to OFF and then to ALWAYS ON it will allow me to switch CH on / off with Hive. With the HW also being enabled, as long as I don't cycle the CH setting, the CH still works but then I am left with no HW. If I then do the reverse, i.e. put CH to off then always on but AFTER select Always on for HW, then only HW works.
I have 2 zones and both the thermostats have the issues as described above and the wiring is the same at the thermostat.
I took photos of the wiring of the original and the new wiring configuration as below:
Original boiler wiring:
Original thermostat wiring:
New boiler wiring:
New thermostat wiring:
Original boiler setting (when both HW and CH worked on demand):
Hopefully someone with a bit more knowledge on these can decipher where things have gone a miss. I can only assume there is an activation wire/link missing somewhere that is causing this since it worked on the old system and it has failed straight after swap.
Thanks in advance,
Lesta
New boiler wiring:
Thanks in advance,
Lesta
