Hello,
I have a dot and dab wall where the plasterboard is quite thick, I believe it is double plastered? The gap from the surface of the plasterboard (facing the inside of the room) to the brick wall is 70mm.
I want to mount a 55" TV ideally on a cantilever bracket. I have looked at many options and even had someone come in to give a quote on the job.
Option 1 - Use hollow anchors- I have been advised this will not hold because of the weight of the cantilever anchor and the TV which is about 18kgs in total. In addition, I would need longer anchors than normal for the plasterboard depth.
Option 2 - Corefix screws, the ones with the steel sheath around it. Unfortunately, even with the longest screws they have, the steel sheath will not breach the brick wall, I was banking on this option.
Option 3 - Scrap the cantilever and just use a standard bracket. Please can someone confirm that using hollow wall anchors here would do the job?
Option 4 - The guy that came to have a look today suggested something about drilling a hole into the wall, pouring some chemical resin in and then put threaded rods into it so it effectively bridges the gap and sits tight in the wall. At that point, I can then fix the TV on. Unfortunately, the quote was about £500 which is too much for me! Is this something an average person can do?
Is there any other option that would suit my situation better?
Thank you so much in advance!
