Hello everyone,
I'm new on here, so please bear with me
I have a Worcester Heatslave Combi Oil Boiler 20/25, installed in 1998. I've had very little trouble with it over the years, well nothing I couldn't sort myself....eventually! However, recently I have developed an issue which I can't get to the bottom of.....
My boiler is starting and heating up fine, but the CH pump doesn't seem to be running to pump the water out to the radiators. The diverter valve is fully swung (powered) over making the micro-switch (checked by multimeter) which, to me, should initiate power to the pump motor? The pump doesn’t seem to be running though, so the boiler internals are understandably really hot. However, when running a hot water tap, water then seems to be pumped to the radiators and they become red hot! So, the pump is working, but not as it should in my opinion. The hot water is hot too, by the way.
Once the radiators have been supplied with heat, the CH stat on the facia becomes responsive again i.e. it will on/off the burner. This stat is very course to move though, whereas the HW stat is free (recently replaced). I'm thinking to replace the CH stat due to it's sticky nature.
I have checked the diverter valve and it is free to turn by fingers. I applied a bit of lubricant to the spindle and reassembled the top parts.
I replaced the Flow Switch two days ago, as it was weeping and I couldn't get it tight (I eventually cracked the casing of it). I suspected that it might be part of the problem. Alas, I think it has helped with another issue, but not this one.
Do you have any other suggestions as to what might be causing this problem? Could the internals if the diverter valve be an issue?
Regards,
Robert
Regards,
Robert
