Hi plumbers and DIYers
I made a post about my 3-port valve a couple of weeks ago, but have finally been able to take a look and thought best to start a new one than tag on. Hope that's ok.
Recap: We've had a problem whereby our boiler will only heat the radiators, even when set to hot water only. Pretty certain the problem is with the three port valve.
With the electricity off, I've removed the head and taken a video to show what happens internally when I move the lever. As you'll see, it slips and clunks. Does that mean that the gears are knackered or is it something else completely? Is it fixable or time for a replacement? Or is it normal? Must say the vids I saw had smooth looking mechanisms...
If it is time to replace the head, should I just do that or do the whole unit? The spindle moves quite freely by hand, as per the third video. It only moves from say 12 to 1 one o clock, but I think that's the normal range isn't it? Is there any other way of telling what condition the T pipe piece is in?
Money is really tight, and if just the head needs replacing I'd be confident doing that myself plus the part would be a bit cheaper.
But in a few weeks we are having plumbing work done in the house which will involve a drain down. So if it is a much better idea to change the whole thing then that would be the time to do it, and I'd bite the bullet on the extra £££.
Hopefully the videos can help shed some light:
https://drive.google.com/drive/folders/1uDVtF8t8_L7f5pekzgGtGM89wzy4q7nN?usp=sharing
Much appreciate any replies
Cheers
PS - Hollywood here I come!
Cheers
