I have a Bosch Dishwasher Serie 4 (SMS50C26UK/D3) that is showing E02. According to this website E02 is a Heater Relay fault. I have removed the computer from the appliance and removed the relays (there are two) from the PCB and tested them out of circuit to ensure they operate correctly. They do.
The relays are DPST and there is one for Live and one for the Neutral so Bosch have doubled up the contacts for each line.
I then soldered the relays back into the PCB and ran a cycle whilst monitoring the voltage to the coils. I can see 13.4V continuously on both relays either side of the coils. At no point do I get a 0v that would cause the relay to switch the mains to the heat pump.
Does anyone know which sensor would cause the PCB to energise the coils and switch the relays or any other advise on what is going on?
Many thanks
Many thanks
