- Joined
- 17 May 2012
- Messages
- 11,378
- Reaction score
- 1,001
- Country
Surely the joist hangers would go onto the wall plates in the event that there isn't sufficient space to get them in atop the wall plates
yes, that is what I meant - you said it better!
I don't quite understand you. Are you saying get some very long joists in to go across the rafters from left side of the garage to the right and fix them down then fix the bracket to the top of the joists? and if not feasible use smaller pieces and joist hangers?
A quote from a technical paper (called "The Seven Deadly Sins of Trussed Rafter Construction") on Fink truss roofs: "Typically the bottom chord of a truss is designed for a superimposed load of 0.25 kN/m2 which the author often refers to as empty cardboard boxes loading."Be doubly amazed then because they are also designed to take a snow load of 60kg/m² which is similar to tile loads
I'm thinking those blocks are 440 long so span nearer 5m?A quote from a technical paper (called "The Seven Deadly Sins of Trussed Rafter Construction") on Fink truss roofs: "Typically the bottom chord of a truss is designed for a superimposed load of 0.25 kN/m2 which the author often refers to as empty cardboard boxes loading."
So whilst the top of a Fink truss frame is designed specifically to carry the load imposed by the roof cladding, snow and wind, the bottom chord is designed to carry only a thin skin of plasterboard and little more. Not surprising when you consider that the bottom chords on this roof are 75 x 38mm (3 x 1.5in) on about a 4.1m (13.4ft) span (based on those blocks being 340mm long blocks)
There are exceptions to this, where the builder has specified that the bottom chord be capable of supporting a load, but that does need to be specified at time of manufacture
Yes, long joists, like the bottom ones there now, but it will be much bigger and not support anything above, just for the bag. I don't know how to calculate the size, so just go big!
Completey disorientated, what is width of garage?If you are referring to the rafters in my garage yes the garage is just shy of 6M long (back of garage to garage door)
Just to add they appear to be extended further down using those metal plates that hold the rafters together
