- Joined
- 16 Oct 2021
- Messages
- 663
- Reaction score
- 71
- Country
I have had a full central heating system installed, all new pipes (that's every single inch of pipe has been replaced) and all new rads (16 off)
The property is over 5 levels with rads on all levels and the boiler is at the highest point in the roof space
The boiler circulating pump is on the return side (so water is effectively pulled back rather than pushed forward)
Rads on level 1 (Top (2 of them) always get hot
Rads on level 2 (1 of them) always get hot
Rads on level 3 (5 of them) only 4 get hot, the fifth is on-off
Rads on level 4 (2 of them) always get hot
Rads on level 5 (6 of them) is where the big issues are.
Some days a rad will be hot, then other days its cold. Then the same rad can run hot and another rad that was hot is now cold. So they seems to alternate.
I've checked to ensure air removal from rads and added auto vent part way in circuit (boiler also has auto vent)
I've balanced (as best I can) the system
Anyone any suggestions as to what is happening?
