Sink Tap
7 Jan 2011
North
Ireland
Hi
I have the tap on a sink in a toilet but the water flow has really slowed to nearly no flow at all.
I have taken the cartridge out and its seems fine but the water trickles from the tap.
Can the tap be the problem or could it be the pipes? I have copper pipes hot/cold running down wall with flexi tail pipes into the tap.
Any advice would be appreciated.
Twisted/kinked flexi tail seems a likely culprit, or have you turned any isolation valves off recently on the same feed?
Just took the tile off over boarded area where I have isolating valves and low & behold unscrewed the flexi pipe to reveal white stuff clogging the hole.
Cleaned the flexi pipe refitted the washers screwed together again and bingo tap running like a tap.
What could the white stuff be any ideas?
Hard water area - Fit scale reducer. What’s your cylinder thermostat set to (if you have one)?
Not sure what thermostat is at but I have renovated other bathrooms before this one in the house and have no problems.
