- Joined
- 28 Apr 2004
- Messages
- 8,411
- Reaction score
- 1,008
- Country
One can, but as I've observed before, the last couple (maybe three or more) times I have suffered 'loss of a freezer', it has been due to failure of the freezer itself, without loss of (including 'tripping of') power. I therefore have temperature-operated alarms on all my freezers. However, they are only of use when the house is occupied, but I'm sure that one could arrange for such an alarm to produce alerts via e-mail or SMS etc. if one really wanted to.You can also buy battery powered alarms, which plug in to the freezer circuit and warn you when power is lost.
It depends on the design of the CU.So can I assume its not a straightforward exercise to put the kitchen ring onto a RCBO in a CU full of MCB's and 2 RCD's - shame!
All good stuff...
If we assume that the o/s security camera is the problem, is there anything that can be done to make it less likely to trip the lighting circuit and hence the RCD?
To recap, its a relatively cheap unit on the o/s wall which catches a great deal of the prevailing weather and is powered through a plastic waterproof junction box and an inside wall switch.
Does that mean that with a 'frost free' freezer (I've never owned one!), if a power cut starts close to the 'worst point' in the freezer's cycle, then there is a risk that one may have have less than an hour before the temp of the contents rises to a level at which food will start to spoil?... But with a frost free freezer as I found out to my cost, if after defrost cycle it fails to restart, you have less than an hour to do something. OK if at the point where it has just turned off the power fails you may still have 6 hours before there is a problem, but it is all dependent where in the cycle it fails.
All agreed, but with the two caveats I always mention:... So insurance and take reasonable steps, which to my mind is a dedicated RCBO to freezer... But the less on the RCD the less likely to trip, so we can reduce the risk ...
If so, then that seems to be a fairly good reason for not having a 'frost-free' one (unless one wants to rely totally on insurance) since most 'true power cuts' (due to network faults requiring repair) will last a good bit longer than an hour.
If you mean that one would be in a mess if a power cut occurred soon after one defrosted manually, then that's obviously correct - but that would require an extremely improbable coincidence, given that manual defrosting only takes a very occasional hour or threeFrost free or not, even if you manually defrost - you would be in a mess if power was lost at the crucial moment.
The way a frost free freezer works is the cooling coils are behind a divider and there is a circulating fan, this means when working all food at -18°C does not matter where it is in the freezer, so much better than non frost free, when it goes to de-frost cycle the fan stops, so only the coils are heated behind the panel, and the condensate runs onto a tray on top of the motor, so once it restarts it evaporates with heat of motor, and there is a delay on the fan starting so cooling coils are cold before it runs.
Fair enough - that's just a type of improvised 'power failure alarm' However, as said, that won't tell you about failure of a freezer which is still receiving power.... I know I had a rechargeable torch on same supply as freezer, with a power cut torch would light, so alerting me of the power cut, as I tend not to notice a lack of a light, only see it when a light comes on.
OK, but that's an extremely uncommon situation. Very few houses are left unoccupied for more than a month and, as you imply, most insurance policies will cover freezer contents (and the consequences of water leaks, wind etc.) for a period of non-occupancy of at least one month.As to insurance ours requires us to not leave the house for over a set length of time, and when it failed were were looking after my mother, so had been out of the house for over a month, so could not claim.
Fair enough. Since it's all probabilistic, it's obviously a gamble, so #experiences will vary'. In our case, helped by the fact that we have virtually always had over-temp alarms on freezers (and we haven't been unlucky enough for a freezer to 'die' whilst our house was unoccupied for an appreciable period of time), we have never (in ~50 years) suffered loss of the contents of a freezer because the freezer stopped 'working' (for whatever reason) - so, had we installed 'all RCBOs' purely because of the 'freezer issue', all of the marginal additional cost of the RCBOs would have represented a 'financial loss'.Hence when I moved here I considered the £300 or so to restock freezer, although not full, and decided all RCBO was the way to go. We have had trips when the roof leaked, but not the supply to freezer, so yes having all RCBO has paid for its self.
Yes, we know that story. As you say, we will never know what would have happened in the absence of the RCD - although, if it 'knocked you out', it's quite possible that the effects of the shock removed you from the source (hence terminated the shock current' almost as quickly as an RCD would have done.I have had one even when the RCD may have saved me, I sawed through a cable not in safe zones I did not realise it was there, it may have saved some one in my family other times, but can't be sure, however it was enough to knock me out, but did not clearly kill me, so it may have saved my life, so thing RCD protection is worth it.
Never having had one, I'm uncertain, but the impression I get is that (given that the purpose is seemingly to avoid frosting up, rather than 'defrost' it once it's happened) the 'cycle' in these machines is very short, quite probably less than 24 hours in duration.Oh, OK - so the defrost cycle could be fairly quick, I didn't realise that.
