Replacing Hive with basic room stat Junior 24i
24 Oct 2021
Hello!
I'm selling my house, so I'm removing the Hive I installed and re-wiring the room stat (I THINK that's what it's called. Basically the thermostat on the wall with the temperature dial for when the heating should turn on/off) back in that was originally there pre-hive.
It seems really straight forward, but I just wanted to check. It's a Worcester Bosch Junior 24i with a DT20 programmable thermostat installed.
This is the current wiring from the Hive.
The existing room stat that I'm putting back in only has 2 wires, a live and neutral wire.
So, I obviously need to remove the Hive wires from Ns, Ls and Lr.
My guess was that the neutral from the room stat goes to Ns and the live from the room stat would go to Ls or Lr, but I'm not exactly sure which one.
Any help would be much appreciated!
