D
Deleted member 267285
Only other way I can think of is to waterproof the concrete? https://waterproofcaulking.com/what-to-expect-from-concrete-waterproofing/
How do civil engineers prevent their manholes filling with groundwater i wonder?
By extending the well pipe as continuous pipe to a height above the ground level. No manhole involved. At least that is what happened at boreholes that friends have had installed, and it makes common sense to do that.
Yes it means the well head is visible ( as apposed to being buried and out of sight ) but that is a small inconvenience compared to having contaminated water.
It is a 6 inch diameter bore hole, is this something that could be easily achieved? i have no idea if they have extension pipe they wont return my calls. They have my money no longer care.What size is the pipe coming out of the ground that the Well company have fitted?
Do they have extension pipes that they could fit?
Andy
How about made a ply enclosure around it then fibreglass the inside and outside. Also fibreglass uptown and around the centre hole. Does the pipe stick our the ground enough to get a seal on it? Then cap the the top with a lid.
Thankyou very much andy. I can get to the well head, so extending its height somehow may be a suitable solution. Thankyou everyone for your advice it is really appreciated. Im going to try my luck waterproofing the concrete and inner chamber with isoflex primer and liquid rubber. If not then the only solution is most likely to extend the height of the well head. I just cant understand why the well men removed so much from the top...https://www.drainagecentral.co.uk/F...MIovzj1_Dy8wIVhIBQBh3PFwIiEAQYAyABEgK87PD_BwE
https://skyplastics.co.uk/160mm-und...MI5dn54_Dy8wIVNoBQBh1anAtyEAQYAyABEgItivD_BwE
These might help if you can get to the well head?
Andy
