Replacing analogue thermostat with digital (1)
5 Nov 2021
Hi I have 3 zones in my house with analogue thermostats, I want to upgrade to the Honeywell home dt90 can anyone point me in the right direction for the wiring I’ve attached pic of the analogue wiring and the back of the new thermostat casing any help much appreciated
This is the analogue thermostat wiring diagram
Live and switched is easy enough (1 and 3 to A and B respectively), just unsure about the other one, either pump or motorised valve?
Your present thermostat is actually wired the wrong way round - assuming brown is Live.
It should be Live to 1 and Switched Live to 3 - which will be L to A and SL to B.
That's all you should need.
Where is the lamp shown in the diagram
hi the old stat was working can’t get this thing to go at all ‍♂️
