Old British Gas Up2 thermostat doesn’t turn off heating
17 Nov 2021
I have British Gas thermostat UP2 for 10years, worked very well. I turned heating on yesterday as it was a bit cold. The hot water is in timer , but the heating advance and once button didn’t work , only select the ON button, the light is on and heating comes . But the heating won’t turn off even I select the off . Anyone can help me please?
Thank you
you will have a 3port valve (Y plan) or 2 x 2port valves (S plan ) post pics of what you have probably next to the HW cylinder
Thank you @ianmcd
I still couldn’t figure out which one is thatvalve .
On the pipework, usually around where the pump and pipework is (as suggested usually next to the hw cylinder), would look like one of these.
th
th
Thank you
Hi Delia, I'm facing the same problem. If you managed to solve it, can you please let me know how, thanks.
