Can anyone please offer advice on a Hive single channel install..?
I have a Warmflow Utility 70 HE connected to a mechanical timer from the stone age, I dont know what it is. (pics attached) Power was hardwired to the timer from a non working switched spur. Outside in the boiler house the boiler and pump are plugged into a double socket and from the sockets 3 wires come in to the timer (2 black numbered 1&2 and an earth) there is also a 3rd black which has been either cut or broken but the timer and the heating work correctly so I assume it was cut. Its a simple on/off set up it heats the house and water at the same time.
I've fixed the switched spur and connected a single channel Hive receiver in every configuration I can think of but get nothing at the boiler. Hive lights up, connects with hub and receiver and shows green light when I use the manual heating on button.. Spent last night without heat so reconnected the old timer this morning works just fine, I havnt damaged anything but I dont know how to move forward..
I have connected the N&L from the spur.. Then tried the 2 wires from the boiler sockets to 2/3 2/4 and tried a jumper from L to 1 on the Hive..
These are pics of the timer I am removing along with a diagram of how its presently wired..
I'd be grateful for any help..
