Changing a circuit breaker
6 Apr 2006
Leeds
Hi
The electrics have gone to my garage.
It has it's own mini consumer unit with a 6 amp and a 16 amp circuit breaker.
When I presss the test button nothing happens so I presume there is no power getting to it at all.
All the house electrics are working except this.
It runs from a Proteus Geyer 20 amp breaker in the kitchen consumer unit.
There is an identical one in there for a different circuit that works, how do you change them?
I thought I could swap them over to test if it has failed.
How do you get them out?
Ta
Granny
If you don't know, don't do it. You will be working on live equipment.
Do you mean a 620B
Simply swapping supplies over is not the answer nor is it a valid way of fault finding.
You need to check for voltage present on the outgoing side of MCB supplying the garage unit in your homes consumer unit and if there is voltage present there - also at the incomer to that garage unit. If there is no voltage present at either point, is there voltage on the incoming side of the MCB in your homes consumer unit and so on.
Does the supply cable go direct to the garage unit?
Where you doing anything when the electrics “went” in the garage?
what if there’s a fault which has taken out the MCB and because you’ve not fixed it, it will take out the second MCB?
Begging your pardon willy, but the OP asked if he could swap one 'breaker' for another, to see if his garage 'breaker' was faulty. Which seems to suggest he is lacking in test equipment. Swapping the cable from his 'breaker' to an alternative 'breaker' then does become a valid method of fault finding. In other words, you work with what you have when diagnosing an issue, rather than what you would ideally like to have.
I don’t think advising people to work in that way is a great idea. With none lethal mediums, absolutely. But not with electricity. The fact that he seemingly has no measurement equipment suggests he can’t even check for dead to make sure the main switch is working or that nobody has done the dirty and wired something to the live side. I agree you work with what you’ve got, but I also remember that we are qualified electricians and I just can’t bring myself to advise people to do something that 1) is potentially dangerous and 2) they have no idea about.
It was working fine when I went out. Came back and it was not working.
No one was in or working on anything.
Thanks for your help but I will get an electrician it's more complicated than I thought.
The OP had in mind to tackle something even more potentially dangerous - swapping the 'breaker' over in the 'board'. I advised him against that and suggested a safer method.
