So the DIY'er has made 730 posts in a month which are all his opinion only. As a professional I've made just 2100 posts in 12 years, mainly because I am too busy working to sit at my keyboard all day. My posts are all based on professional experience. With regard to olives on compression joints, the last thing I need is a call back to a weeping joint, but where it is necessary to remake an old joint, I know from experience how to do it. I also know that if I do put ptfe around an olive, the last place it will ever get is in the flow of the pipe as he staed in his last post.
I get very few callbacks, and none I can recall have been to anything as minor as a weeping compression joint, and I make a few, mainly on oil lines where the medium is more searching.
Reading really does wonders doesn't it.
So what’s the jointing method say for steel water pipe say 1” involving steel T’s -nipples-sockets etc?In a industrial application, you wouldn't get the use of PTFE tapes or jointing compound passed on a MS.
Professionals do what experience and trial and error tell us to do. Documentation is created as a guide only and mostly provides the manufacturer a cover all when it comes to warranty calls. Manufacturers. as we all know, are constantly updating their documentation and making changes to their products, I wonder where all that updated information comes from, it's certainly not all based on R&D, it can't be.
If you ask most manufacturers a lot of their practices, procedures, instructions and updates are based upon real life professionals feeding back, industry requirements, toolbox discussions and peer to peer reviews, amongst other reporting vehicles.
I've actually been on a few feeedback boards for McAlpine, Yorkshire, OSMA and a couple of others, that feedback is then taken forward with industry board recommendations and R&D reporting, especially as it pertains to real life issues and then new solutions are constructed and updated documentation, instructions and newer products are created to replace older versions, happens all the time.
These products are mostly market driven, we as plumbing professionals are that market, those products then invariably filter down to the DIY market once we take it up, refine it and make it an industry standard just as in any business. Documentation isn't ever the be all and end all.
ptfe. always has been.Taper thread?
Manufacturer approved thread sealant.
Taper thread joints are a completely different beast than compression fittings.
ptfe you mean?Hemp and boss, etc was used traditionally.
Modern thread sealant is much more advanced than that and is engineered to suit the application, service, materials, fittings, etc.
ptfe you mean?
