Hoping someone on the board can help me with this issue - to which I am sure the answer is staring me in the face...
Problem
Our heating and hot water work absolutely fine on their schedule or manual boost, but...
When the temperature drops each night it triggers the frost stat and causes our boiler to fire up (correctly and by design) however instead of heating the pipes and turning off it is making a loud gurgling / banging noise (maybe kettling if I knew exactly what that noise was) which wakes the whole house up. I've been putting off sorting this because it didn't happen through the Summer and its fairly easy to knock off (see below), but now it's getting on everyone's nerves. I am assuming the noise is caused because the water is not passing through the boiler correctly under an active frost stat and therefore heats to the point steam is created and pressure in the boiler builds.
Specifics on My Install
What I've tried
Current Thoughts
I'm up to my neck in uni work at the moment (as a mature student) so don't really have a lot of time to sort this, but the boiler is keeping me awake at night
- any help greatly appreciated.
Sure lots of the above will not be perfect understanding or terminology and all feedback is welcome
Thanks, John
Problem
- Boiler is an Ideal Icos HE18 located in an integral garage.
- Drayton PTS1 and RTS3 stats.
- Exposed flow and return which disappear into the roof space.
- As far as I understand this is an S-Plan setup in a 2007 home.
- Conventional boiler with hot water tank in an upstairs airing cupboard and header tank in the loft.
- Tank has previously been replaced so likely to have been maintenance on pipes and electrics.
- Honeywell and Range valves for radiators and hot water respectively.
- Boiler has failed 3 times needing new PCB on 2 occasions.
- Have installed Hive home heating controls - replacing programmer and leaving the internal room stat in place but set to max - i.e. Hive stat has control when heating on.
- Water in the area is known to be hard.
What I've tried
- When the issue happens if I boost the hot water for an hour on the Hive app the banging stops.
- Checked the 2-Way valves open and close when the heating or hot water are on.
- Condensate trap has been cleaned multiple times and makes no difference.
- Frost stat was attached to flow pipe but I've moved it to return pipe based on manual recommendations for the stat and the boiler.
- Frost stat was set to 55 degrees and this has now been adjusted to 25 degrees based on manual and recommendations.
- I've tried leaving the Honeywell 2 way valve for radiators manually open so water is able to flow.
Current Thoughts
- Could it be the pump isn't pushing the water round the system when the frost stat fires the boiler? How would I check this?
- Could it be the installation of the Hive was done incorrectly and somehow breaks the circuit for the pump / valve to operate when the frost stat fires the boiler?
Thanks, John
