Fitting Hive to Vokera Linea 24
27 Aug 2005
Ayrshire
Hi All,
Looking for a bit of help with fitting a Single Channel Hive to my Vokera Linea 24 combi.
The boiler has it's own internal timer, there is no external timer or thermostat fitted (as per image).
My intention would be to disconnect the internal timer.
Connect the receiver in it's place using 5 core cable.
L - L
N - N
But this is where I need some advice.
What terminals from hive to terminals on boiler.
Do I leave the link in place, as per the attachment.
Thanks for any help or advice you can offer.
easiest way, your boilers timer will have 4 wires L&N and com and NO, easily identified, connect L&N to L&N on the hive receiver, then the other two wires to 1&3 on the hive receiver, doesnt matter which way round it is just a switch
Thanks @ianmcd.
Do I leave the link in between the TA and = or remove it once the Hive is fitted?
just leave everything else as is, dont touch anything else, existing clock wont turn or do anything, just forget it is there, it is just filling a hole on the boiler facia, the Hive will control everything now
