I am thinking about my next boiler, which will be an Ideal Vogue 32c Max and maybe Opentherm via Halo and whether I should get the Opentherm option and would it save any money and possibly cause a leak in my pressurised piping that has issues?
At the moment my dumb thermostat on a Worcester Greenstar meets my needs. If has 6 time zones 6:30-8:30 19.5C, 08:30-13:00 17C, 13:00-15:30 17C, 15:30-22.00 19:5C, 22:00-06:00 15C.
My well insulated house on cold days doesn't hit 19.5C in the first period but that doesn't bother me as we are moving around. This is no doubt due to the fact that the boiler operates the CH at only 55C with around a 12C drop across each radiator so I consider the Worcester to be permanently condensing. On occasions we do override the daytime temperature by manually increasing the thermostats temperature.
Now the issue. Maybe 10 years ago we had a leak in the central heating system, which could not be found. It was cured with a bottle of rad seal that has fixed the problem. This resulted in me keeping the pressure gauge to a fraction under 1 bar cold so at 55C I get 1.5bar.
I understand Opentherm ignores the boiler controls so could pump out a lot of heat at 6:30 so not only increasing the boiler to a non condensing temperature but possibly increasing the pressure so it pops my rad seal in some hidden pipe.
Have I lost the plot? Will I save any money on gas costs? Will I threaten my rad seal?
Also, while I am thinking about it, with Opentherm does it turn the heating on early to get to 19.5C for 6:30?
