I like double negatives
However, I get very frustrated by the 'multiple negative' statements one increasingly finds on some websites, such as:
"Do not tick this box if you do not want us to not send you marketing rubbish"
How many times does one have to read such a statement (and maybe do some scribbling) before being sure what one should do to achieve the required result ??
... and, even then, I sometimes 'get it wrong'!!
However, this is neither new nor restricted to 'marketing rubbish'. Many decades ago I took some major professional exams which consisted of several 'parts' (all of which one had to pass, separately). We all waited with bated breath for 'the letter' to come through the letterbox, and then found oneself reading something which said something very close to ...
"We have to inform you that you have not failed to satisfy the examiners in relation to the following parts of the examination."
Only really effectively a 'double negative', but I cannot tell you how many times we had to read that, whilst in an emotionally-disturbed/excited state, before we were certain whether we had passed or failed (overall)
Anyway, after that diversion ...
I'll give a scenario that the original wiring was a single solid wire doubled over shown red .... and the black and green wires added later. .... EDIT: But I still say getting lots of wires into one terminal is more likely to lead to subsequent failure if the wires are moved, such as fixing the accessory into place.
It obviously 'depends' on the particular situation - particularly when, as you describe, further things are subsequently done. However, I still stick to my view that, in general, the 'clamping securely' of all the conductors is more likely when several conductors are 'crammed in' to a terminal than if there are just one or two conductors 'floating around, with lots of room to spare' in a large terminal.
