Screw Stuck - head chewed up
21 Mar 2021
Hi
I have tried using a rubber band and the drill on a slow setting (reverse) but I still cant get the screw out.
Just wondering if there is anything else I can try before calling in the pro's?
Many thanks
Chip it round with a sharp centre punch. You only need to be able to loosen it, maybe 1/4 of a turn.
I would if I had a centre punch. I will add this to my list of wants. Thanks. Locksmith coming out tomorrow.
flat screwdriver about 2/3ds the star width tapped in
check you are using the correct driver as in pozi is a star within a star both screwhead and screw and Philips a star and different point angle
Have you been using a cordless screwdriver/drill and running it clockwise instead of anti-clockwise?
As Stivino says, a 1/4 turn anti-clockwise will have that screw loose enough to spin out using the end of your finger if you wanted to.
Hi
Many thanks
You have probably been using the wrong bit, it’s Phillips head, a posidrive will damage it.
a small left handed drill will usually help you get those out, if it starts sticking to the metal of the screw, then the screw will unwind out for you
