Hi all,
I've designed and installed the timber work for a flat roof within a parapet wall on our self build extension. The fall is from the rear to a drain gulley at the front which exits through the wall in to a hopper.
The fall from back to front over a 3.4 span is 50mm to 0mm which achieves the minimum 1:80 (it's actually 1:68 which is all good) as I see the regs 'encourage'. That's all fine. However I've just realised that the gulley at the base of the fall which is 5.4m long itself only has a 50mm fall which 1:108..
I know this will work as I've checked it with laser level and there is no chance of deflection/settling as the gulley construction is bolted through to the block wall - so it's less than ideal but also is and will remain a consistent downward slope to the hopper. But... could it be a building control issue?
In the regs it's the word 'encouraged' 1:80 minimum fall which suggests that it's simply the home-owners issue if it doesn't quite achieve that. I thought I'd ask for the input of pro's on here just in case though! If really necessary I could remedy the fall along the gulley to just about make it meet regs but I'd rather leave it as it is and crack on with GRP.
NB: The design was based on what the architect specified so not just me seeking to cut corners. The architects original spec was for 50-0mm firings along the length of the gulley.
Thanks in advance for any input.
