I am approaching the installation of my new kitchen. I have a separate built in oven to be mounted 3ft off the ground in a tall appliance unit with an isolation switch in an adjacent larder unit. The switch is an MK grid switch 20 amp rated.
My question is:- can I just surface mount a single gang box with the connection unit to the inside of the adjacent larder unit with the oven cable passing through a hole between the larder and appliance unit? The cable will be in surface mounted conduit where needed.
or
Does the connection unit have to be wall mounted behind the oven?
The oven has its own separate feed from the consumer unit and draws less than 13amps.
or
