On my previous thread you kindly explained about the permanent live forth wire to an Ideal Logic Boiler at my son's house.
You'll remember I was concerned it may have been fitted on the input side of the isolating fused spur making it a bit too permanent.
While waiting for that to be resolved by the installers I had a look at the Wiring Centre today in readiness for fitting a Nest Thermostat.
At my own house where I fitted a Nest in February the Honeywell Wiring Centre is simply a box containing 10 connections. At my son's house it is an altogether more complex arrangement.
There seems to be 3 Blue, Red, Yellow, Green/Yellow and 1 Black, Red, Green/Yellow flat cables coming in along with the YPlan 5 core, the Cylinder Stat cable and the Pump Cable.
I could be mistaken but when the Fused Spur to the boiler and the MCB on the C/U were turned off there still appeared to be power in the box.
Q1. Can you help identify where all the wires come from ( I realise some are obvious) so I can end up with a diagram that includes the Google Heat Link and the Nest thermostat?
Also which part of the board is covered by the fuse?
The fused spur at the side of the boiler appears to have 7 wires connected to it.
Thank you
Ray
Thank you
Ray
