Hi all,
I'm looking for general advice how to approach this as I have a very annoying intermittent problem with our new boiler, fitted a fortnight ago.
Just to describe the system, we've got a Vaillant Ecofit 425 and we had a Gledhill Stainless vented Cylinder fitted at the same time, it's a conventional system (cold storage in the loft, header tank for the central heating)
Our problem which has started occurring the last few days is that the heating has been tripping the RCD but completely randomly at different times of day, it can run fine for 15+ hours and then suddenly trip.
The only way I can get the power back on when it does trip is to turn the power off to the boiler at the wall switch, switch the main board back on, then switch the heating power back on and quickly set the water/heating to off at the controller before it trips again.
Initially I suspected it was the pump, but the more I think about my process the more I think it's the boiler.
Reason being is that when I get the power back on, as long as I've set the CH/Water to Off at the controller, the pump will still run (like it does when it overruns) which seems to indicate the pump is okay. This leads me to think it's me stopping the boiler heating that stops it tripping... it tripped last night at 0100 when there was barely any other power being used in the house.
I've spoken to the fitter who's a bit stumped, he suggested calling Vaillant or an electrician, on the basis an electrician isn't likely to get inside the boiler I've decided to call Vaillant out. I don't know what these guys are like for diagnosing intermittent faults so I'm a bit worried they'll turn up, won't be able to get it to trip and then bugger off...
At the moment we're having to set the controller to off for water/CH overnight to avoid it tripping the RCD while we're asleep... so it's a bit of a pain
Sorry for the war & peace, I'm just looking for insight from the experts here as to what might cause the RCD to trip after such long periods? Hopefully my process above makes sense and is logical.
