Dust vacuum in Lidl
30 Mar 2022
In the local Lidl they have dust vacuum cleaner for doing really dirty/dusty jobs like the chimney/hearth area after sweeping chimney etc.
I cant find it on the web page to show it, but here is something similar on ebay
My question is - would this also work as a dust extractor to use in a workshop doing some machine wood work?
Would work for light use.I use an old Henry vacuum in workshop .
I use an Aldi wet and dry with power take off.
This means the vacuum starts with tool use and runs on for 5-10 seconds.
I can put HEPA filters in and it's great
Aldi have one at the moment but without the take off.
But Screwfix do have one
£75 or so
My Aldi (scheepach?) one works great on a sander
I think the two obstacles you may experience are inadequate filtration and inadequate capacity.
I used to have a Goblin ShopVac which worked well for ordinary vacuuming, but which sucked stuff up and blew it straight out the back when sanding MDF or plaster. These days I'd probably either get better (HEPA) filters for it or build a pre-filter cyclone unit to take the fine stuff out. If yours ready has HEPA filters then happy days
18 litres is a bit small for woodworking - furtunately the only thing that means is that you'll need to empty the unit more often
One thing about soot is that is a actually quite sticky. What that means it will clog-up filters, even the washable ones. I've ruined a few sets of filters with the stuff
Mine has a cartridge filter, but I mostly put a paper or white synthetic bag in as well to delay clogging. I keep a spare cartridge handy to swap.
30 litre nominal holds a lot.
In a workshop you can run plastic waste pipe to your main tool positions and tuck the vac in a corner or even outside.
Cheers for that info. Yes, I have seen those traffic cone type homemade cyclone filters on YouTube and wondered if a DIY solution might work in connection with a vacuum.
Thanks for that tip - handy to know
I also think the power socket is a valuable feature. Screwfix have one.
Power take off.
ie the tool can switch the vacuum on automatically
like this one for example
not all models have it
especially handy if you are using an extended hose, or plumbing pipe, and can put the vac outside. that means it is not blowing the dust around your working area.
Cyclonic pre filters will only only separate large particles from small particles. The large stuff will fall in to a bag, the nasty stuff will be too light to end up there and will move in to the main bag.
During lock down, I did mock up a set up but most of my dust is very fine. All of the fine dust was sucked to the top of the cyclone and straight in to the dust extractor.
