Hi All, I have about a dozen solar panels on my roof and box in the garage. I get a cheque every quarter from BG totalling probably 5-600pa. is there a way i can use the energy instead of selling it back? and is it worth it?
We have a fit contract with bg. I cant believe we are using any of the power
What do you mean of course you are? How do you tell? I cant believe my bill before these rises is £140pmof course you are.
How do i do that? my immersion has an electric switch which we’ve never turned on. I assume we are heating the water via boiler?your 2 choices are either use your spare electricity to heat your hot water tank with an immersion or you can get storage batteries so you can use the electricity when the solar panels aren’t charging and you could add an inverter / air conditioner so you can heat and cool from the electricity.
of course you are.
when your panels are generating 2kW, and you plug in a 3kW kettle, what do you think happens to the power from the panels?
The panels should be wired back to the consumer unit and that electricity should be used. How can this usage of the solar electricity be seen or quantified?
How do i do that? I have small meter which is where i take the fit readings from and the large box.
All i know is when i moved into this house my bill went up from £100pm to £140 and now telling me £350pm
its a bigger house but our usage hasnt really changed so £40 rise and im getting some from solar?
