Excess pipework
20 Jul 2010
Kent
I had a heating water tank taken out years ago and opted for a combi boiler.
It looks like there is a lot of excess pipework left, would it be easy to remove the excess pipework as per the red markups in the attached?
You should have got a plumber in the first place then it would need doing.
You should put that on the Good bad and the ugly thread.
This is the original pipework that would of been installed when the apartment was built in 2001.
I paid British Gas £2900 in 2014 to remove the original water tank and install new combi
It's not good enough. You paid good money and you should at least expect good work
You should have called them to come back in 2001 and do it properly!
This was the original tank installed with the property built in 2001. I purchased in late 2014 and the tank started leaking during the winter so was happy just to get heating at the time.
just trying to get it tidied up now
Excess pipework not a result of BG's work then?
BG must have used the white HEP fittings, the old JG were obviously the originals. Get a plumber in to open up the floor and get rid of a lot of that. Or do it yourself if you're handy enough.
edited for typo
All very confused, but I think that the OP is now suggesting that BG had absolutely no involvement in the creation of that pipe mess at all.
