Hi everyone,
I'm looking for some advice.
I replaced the “invisible heat” thermostats and wiring centre for a wet underfloor heating with Hive.
The underfloor heating has 4 zones with a thermostat on each zone.
The engineer installed one hive receiver for each zone. Four in total.
So far so good. It all seems to be wired correctly and working fine. However, when you select a zone to heat all the zones go on. Basically an on/off switch. I cannot warm up zones individually.
I consulted with other engineers to see what can be done. Apparently Hive doesnt work with this type of underfloor heating systems. The engineer suggested adding relays that would open the valves or pump. Not sure about the technical details and the cost, or how effective that would be.
The other options is to replace it with other alternatives like heatmiser, that seems to work straight out of the box. Waiting for a quotation to compare the impact.
Before taking any steps I wanted to get a second opinion.
Is there anyone one in this forum that may have some ideas what could be wrong?
I attached some pictures of the manifolds and hive installation for reference.
I appreciate any advice.
